I don't expect any easy answer to this but I'll give it a shot. Using DJI GO 4 (android) if I select flight record and select a flight and then choose either satellite or hybrid it brings up a map. The problem is that in the area I generally fly, this map is many years out of date, at least 8 years, maybe more. Obviously Mapbox don't update maps as frequently as Google Maps. I guess DJI use Mapbox because they may well be cheaper.
Mapbox do have a 'Improve Map' option you can go through and you can suggest that they update it, and I've done that a while back but I've no idea when that might happen. It mind sound minor, but the land use has changed so much over the last 10 years that the map on the app is useless for me unless I took note of the the long. & lat. co-ordinates and then imputed them into G Maps.
Has anyone any suggestions ?
