Welcome Mavic Pilot!
Jump in and join our free DJI Mavic community today!
Sign up
Mavic 2 Atti mode
sar104
Dic mihi solum facta, domina.
Reaction score
11,816
Los Alamos, NM
I haven't seen anyone else mention it so, just in case anyone is interested, I can confirm that it is possible to switch the M2P into ATTI mode by changing the mapping on the flight mode switch using the same DJI Assistant functionality as with the MP. I altered the Sport mode setting (8) to ATTI (3).
It doesn't quite work as seamlessly as on the MP - if it is switched to ATTI before motor start it gives the usual "mode switched to ATTI" message, but on motor start it switches back to P-GPS. Switching it to ATTI after motor start works correctly.
el_powpow
Reaction score
Thanks a bunch, i really need atti mode for training purposes and DJI Told me its not possible on the m2p. Good to know it can be done.
Talley
Reaction score
146
Thanks for the tip. This just told me to upgrade to the current DJI assistant too
gnirtS
Reaction score
2,216
Very useful - i wasn't expecting older versions to work with or talk to the drone.
I guess you can't remap the tripod direction of the switch to it?
gnirtS
Reaction score
2,216
Thats even more useful. I dont use sport much but like it as a backup in case the wind catches me out. Tripod i rarely use. Could be useful...
gnirtS
Reaction score
2,216
So latest one to flash firmware then the old one for ATTI.
I dont really use assistant at all in every day life so just changing that parameter will probably do. I'd just assumed they'd make it deliberately incompatible.
rfc
Reaction score
199
You will need the current version for anything else you want to do - 1.1.2 doesn't properly work with the M2, but it will read and write parameters.
I'm looking for the thread from ages ago wherein you tell us how to change parameters in 1.1.2. (for the regular MPP).
Joola
Reaction score
112
Los Angeles
This is awesome! Thanks for sharing. Hopefullu this doesn’t get patched in future FW updates.
sar104
Reaction score
11,816
Los Alamos, NM
This applies to working on a Mac - it's a little more involved on a PC. Use the standard method to access developer tools (command-option-I), then go to Local Storage: file://
Set "debug" to "1" and "debug_enabled" to "true":
Then connect to the aircraft, choose "Parameters" on the left, and filter for "fswitch":
Here I've changed the right switch position Sport mode setting (mode[1]) from 8 to 3, which is ATTI. In this list, mode[0] is the Tripod switch position (left) and mode[2] is P-GPS (center).
WARNING: do not play with settings that you don't understand, and note that the default parameters governing height limits, NFZ settings and other firmware safety features cannot be overridden - they are fixed, so don't bother trying.
nil
Reaction score
28
Can this be done with a DJI Assistant version < 1.1.2 as well? I have a old 1.1.1-2 installation on my laptop.
Talley
Reaction score
146
Is that a trick question?
Nope. I’ve gone 67mph on the phantom 3 pro in atti mode. Gotta get high go full throttle downwind and full down stick. You get crazy fast.
The current models non atti just reduce power and won’t let you go faster than 45mph. You need atti mode to do it.
Reactions: Fplvert
sar104
Reaction score
11,816
Los Alamos, NM
The point is that it depends entirely on the wind speed. You simply add the top speed of the aircraft (airspeed at maximum pitch) to the local wind speed to get the resulting ground speed.
Reactions: Floater
T1 Drone Services
