Well actually, this version of the M2ED was created to back up the M200 and XT2.Ok, just as I suspect. Max usable distance to see someone is about 100ft away using thermal. So good for checking temp of something you already know exist, but not good for trying to find something using thermal that you don’t already know about.
Inspection only, not search
We're still continuing with development of our Boson 320 M2 solution for this reason.
It is aimed squarely at public safety agencies (UK only) and is set up for this specific task. Controls are minimal and simple, plus we've added physical buttons and switches to the RC so the essential camera functions (record, photo capture, zoom, thermal/visible light toggle, colour palettes, thermal gain) can be controlled very easily without having to move your hands from the sticks. This also means you don't have to touch the app in flight, so you can fly with gloves on. Useful for a 20 minute mission in winter.
Only problem is it will be more expensive than the M2E dual, but that's due to the Boson sensor which is about £1300 Vs £250 for a Lepton.
The Boson 320 with 6.3mm lens will easily detect a person at 400 metres, a Lepton will not. The idea is that for searching/monitoring people from distance the Boson solution will be far more useful and, most importantly, far quicker to detect a human heat signature when searching a large area.
Because the Lepton relies on a visible light camera for MSX enhancement, the night time performance is poor. The visible light camera obviously won't detect much at night.
I can answer a couple of these but not many.Was wondering the same... maybe too early to know, but was wondering if able to purchase the small M2 Dual Gimbal separately and use on M2 or M2E. DJI also states Pro / Zoom not User swappable but that can easily be performed with the Pro & Zoom gimbals beginning to appear on market. If Dual Thermo uses the same physical mount & ribbon connection, hopefully the FW would recognize.
I've played with a Yuneec ET 160 resolution thermo and it was basically useless other than close Inspection work. Examining XT's 330 vs 640 clearly shows the 640 resolution is required for any distance... both XT & XT2.
A previous post above indicated Temp Reading, to verify this unit is not radiometric... correct? On the video when mentioning Temps, it was more the standard "zone" temp, not radiometric accuracy.
Unlike the XT2, the videos don't show the M2E Dual can overlay or show both RGB & IR images on screen simultaneously. Did I miss something or is that correct for this dual setup?
Having MP, MA, I1, I2, M210, M600P & RoninMX, I was pondering adding the M2 to Inventory with both Pro / Zoom gimbals (1 bird, 2 gimbals) and possible sell MA & MP... and then the M2E was released... read & watched reviews, now the M2E Dual. For the use of the M2, I'm still not convinced there's any gain over the standard M2 for "my" intended scope of work using either Pro or Zoom gimbals. The most appealing component of the M2E are the self heating batteries which I'm pretty confident will work with all the M2 series... the M2E's OcuSync2 is nice but not sure a big benefit over the M2's electronics improvement over the MA & MP.
I was waiting on the M2E Dual to see if IR would be 320 resolution and dual overlay. I personally feel it fell short of expectations.
I'll post some photos later on - there is a photo of our very early prototype on my thread here:Sounds interesting... you're doing this on the M2, is it separate transmission & monitor or incorporated with M2 FC?
Any photos you care to share in the development stage? The Boson also offers a 640 and multiple lens options. Any reason you went with 320 & 6.3mm ?
Mavic 2 Flir - An Analysis
We've since updated the visible light camera and it uses the original M2Z camera, so it has full quality and optical zoom etc...
The Boson 640 will fit onto an M2P gimbal but you can't fit anything else on there if you do that. It's also incredibly expensive (I think the last quote was about £3500 for a Boson 640!) so the 320 seemed like the sweet spot here. Obviously just having a thermal camera with no visible light cam would be limiting. We chose 6.3mm because the FOV is about right for SAR use. We can of course use a 4.3 or 9.1 if anyone requested it since they're the same size.
It is fully integrated with the drone and the thermal video shows through the DJI Go app, yes. Essentially we are switching between video feeds to the core board.
At present we are only developing for the M2, and it's based on the Zoom. Using the Zoom gimbal (Pro would be better as the gimbal is bigger, but we want to use the Zoom camera). Assuming the camera on the standard M2E is the same as the M2Z, then yes it will work on that, however the processing boards are currently sitting in a dome on top of the drone where the M2E accessories mount.Very nice... looked at your prototype setup. That looks like a nice setup. How’s it work in the gimbal; Range of movement and balance for the little gimbal? The 320 would defiantly be a huge improvement over the 160. It would more accurately meet the M2E Dual statement of purpose as a close range partner to the M210 XT indicated above.
You started on the M2, does current design require the M2E or include the M2? Like many, I’d probably be using the M2.
Your project looks more inviting than the M2E Dual. And, it should be able to swap to Pro 1” or standard Zoom... correct? Where are you on project and market time?
Have it added enough weight to significantly effect flight time? At this stage, any projected price point?
Aiming to have a demonstrable prototype before the end of Jan, and price is currently looking around 4000GBP plus taxes, so it is a fair jump in price. That's down to the Boson sensor being significantly more expensive than the Lepton unfortunately.
