Yesterday these two posts popped up:
DJI picture 1
DJI Picture 2
#2 was released by the Enterprise team and right now everyone thinks that it's a thermal accessory for the Mavic 2 Enterprise. Makes perfect sense, DJI would be incredibly dumb to not do this. Question, is what sensor? The accessories that already exist for the M2 are pretty small and lightweight, and a thermal camera will need a gimbal. It will also need to have the sensor placed far forward, beyond the nose, so it can see downwards. That rules out any sensor large than a Boson, and a Boson is still pretty heavy at around 40 grams. When combined with a visible light camera for blending/embossing/enhancement/MSX, AND a gimbal, you have a fairly weighty setup to be hanging off the front of a Mavic.
I believe that this system is based on the Flir One, which uses a Flir Lepton sensor. The Lepton is available in 160x120 and 80x60 pixel flavour, with radiometric versions available. One of the above photos shows temperature values so that means it can either be a Lepton 2.5 or 3.5. I'll go with 3.5, so that's a resolution of 160x120 and 56 degree HFOV.
Compare the DJI images with these images from a Flir One:
Flir One 1
Flir One 2
Now, compare that with photos I just took with a Boson 320 to mimic the shots from DJI. One shows my desk with a Mavic and a cup with slightly warm water, and the other shows my phone. These are with a 2.3mm lens Boson so very wide angle at 92 degree HFOV, in reality for drone use you would use a 6.3mm or better. I have one of those too but it's no good for close up stuff.
Boson 320 1
Boson 320 2
Notice how, even with much higher FOV and no visible light enhancement, the images from the Boson 320 are vastly better than those from DJI's camera. Better detail and thermal sensitivity - and you can see the much more crisp outline of my phone for example.
It's probably a bit pointless speculating about all of this until Monday, however this does affect me as right now (Drone Doctor UK) we have spent the last couple of months developing this:
M2 Thermal
This is a very early prototype. We've reverse engineered many of the systems in the Mavic and have developed a solution to switch between a 8MP visible light camera and a Boson 320, with colour palette and digital zoom controllable from the controller. No extra parts, displays, batteries or anything. It all works as you would expect and you use the DJI Go 4 app as normal. It simply is a Mavic with a thermal and visible light camera that you switch between. It's possible in future to implement blending of the thermal and visible light images, however it's not a priority at this moment.
Having spent so long on the development, it was a shame to see that DJI had apparently beaten us to the chase, however from what we can see so far DJI may well have released a very half-baked solution, which would make sense given that they don't want to be adding a competitor to the M210/XT2 range.
Sorry about the non-embedded images, the embedding wouldn't work.
DJI picture 1
DJI Picture 2
Flir One 1
Flir One 2
Boson 320 1
Boson 320 2
M2 Thermal
