- Joined
- Oct 26, 2016
- Messages
- 829
- Reactions
- 645
Seems like a bad decision to exclude it. The other foldable has it. Why would you leave it out solely to protect the P4?
What older foldable would that be? The Mavic Air and the Mavic 2 Zoom do not have 4K60P. The only DJI "consumer level" drone that has it is the Phantom 4 Pro / 4 Pro 2.0 without making the leap into the Inspire line.
If you believe DJI it is primarily a hardware limitation, but if the Mavic 2 Pro had an identical camera to the Phantom 4 Pro with 4K60P and a mechanical shutter, I would struggle to think of one reason to buy the Phantom. At least in the current state of things, then Phantom 4 Pro remains the best image quality you can get in the general category so there is some value there.
The Autel Evo can shoot 4K60P but not with a 1" sensor (it is much, much, easier to get faster readout from a sensor ~4X smaller), so it can't be compared to the M2P, and to my knowledge it is riddled with problems.
Where did you read that? People that own them are not reporting problems in the Autel forum. I favor no company over the other. I just want facts. I considered buying the EVO because here in DC flying DJI is almost impossible with the arbitrary NFZ's. If you know of a series of problems I would like to know that before I buy one. For my circumstance here the EVO may be a better fit but if the video is bad or their are problems I would like to know them.and to my knowledge it is riddled with problems.
I still fail to see much of the value of 4K/60
So then I'm curious. Since the EVO does have it. Are the videos produced at that framerate terrible. Interesting point you make. One that I'm very aware of but.... what do the videos look like?
It is a simple matter of arithmetic. 4K/60 produces twice as much data (at the same resolution) than 4K/30 let alone 4K/24. If all that data is compressed into a 100Mb/s stream which mode do you think produces the best results?
The answer is … depends. There are more variables in the equation than compression. Some systems don't shoot a flat profile making the videos difficult to manipulate in post. Some systems like the new Mavic shoot log flat files easy to edit. Using the wrong card can limit the bitrate etc. etc etc. Changing the lens on a setup can completely change the final product. I don't care how high your bit rate is if the image is not in focus or if the image is not sharp. Recall the first iteration of the Mavic videos. When the system was first released critics were completely discounting the Mavic because they said the image was soft...they believed it was the lens. Then they realized that the twit that was taking the video did not focus the camera. Ruh Roh…. after pressing the button to focus the video it was a totally different ballgame. I'm curious about the difference between the EVO and Mavic 2 Pro. The difference should be large. Considering the specs I'm looking for evidence of that before I spend money buying one versus the other.
Let me put it this way. The Phantom 4 Pro and the Mavic Pro 2 both shoot at the same bitrate don't they? 100 mbps… So you are saying there is no value shooting 60fps on the Phantom versus shooting 1080 60fps or 2.7 60fps on the Mavic 2? I would disagree, just like I will argue that you are incorrectly assuming that there is no value in the 4k 60fps footage of the Autel. I'm going to research it and watch some videos.. If I find you are correct I will be sure to come back here and report it.
Have we established it is not also a matter of heat dissipation? Doubling scan rate of the sensor would also produce increased heat issues. This is a major problem for shooting on GoPro Hero 7 Black with a similar sized sensor in a larger format with improved heat syncs. It craps out within 15 - 40 minutes from heat. Bit rate is 120 mb/s in 4K pro tune mode.
