Hi all,
I'm new to the forum but glad to be here. Sorry to enter with a question already, but yesterday, while experimenting with Waypoints on the M2P, I backed into a tree and the bird fell down to a hard surface, probably an 8' fall after it stopped hitting branches. I lost some props, but I've tested everything out and it all seems to be working fine. No issues at all that I can detect. The only "damage" appears to be with one of the rear arms, and I'm not sure if it's enough to worry about. I have DJI Care but I don't want to send it in for a repair if it's not necessary. The problem is that the arm has a bit more flex in it when fully extended and if I push up on it. I've attached a photo that shows a nic in the body where the arm must have been pushed upward in the fall (beyond the little silicon pad that seems to be a shock absorber of some kind. The flex is VERY minimal and I've noticed no oscillation in flight or in video images. What do you guys think? Thanks!
