Hello, I'm completely new to this forum, and I just need some advice on what to do here.
I just powered up my brand new Mavic 2 Pro and took it for a few Beginner Mode test flights, where I'd just let it hover to about 4 feet and move it around slowly and slightly, testing out the controls. On my fourth test flight, it started to back up into a tree and lower above a pond, unaware of the controls I was inputting. It eventually started shredding some small branches and fell. I went down there to check, and thankfully it only fell onto the ground on some dry dirt. Thankfully, nothing was broken, it was just a little dirty. I tried doing one more extremely careful test flight, but this time, it slowly backed into a wooden fence, and that is when what you saw in the pictures happened. It seems the casing (or something) snapped on the front left leg above the LED. The leg is a little slanted, but it stands up like new. The light works fine.
This was completely due to user error, as I believe I forgot to calibrate the GPS before flight.
I also noticed that two propellers were cracked. One had a pretty big crack, so I had to retire that one. The other one in the picture below has a smaller crack, though I haven't seen it affect performance at all.
Now, I'm aware there is a program offered by DJI called Care Refresh, which is able to supply two new (or close to new) units after damages within a year. I'm sure the propellers are easily replaceable (I'm sure I can get a new set online, though I'm not sure), though what should I do about that front LED leg? Is DJI Care Refresh worth it for this type of damage even though it's not super severe? Will it fix something like this guaranteed? Should I just get it anyway to cover this and in case of an even bigger emergency? Should I just leave it because it's not a detrimental injury? I would love to hear any advice on this. Any suggestions or help is greatly appreciated.
