Stock controller. No DJI RC Pro.Wow, that was fast and far. Was that with the new controller as well?
A simple explanation for youWhat the.. If you can fly that far away, Why cant i?
I feel that his parents would not handle the consequences and if this kid is real and not some troll just trying to aggravate us he would simply blame the problem on someone or something other than himself. This kid is a prime reason for requiring you to be an adult with a drone license in order to purchase and fly a drone so that they can be held accountable when they screw up.A simple explanation for you
Two wrongs do not make a right.
It should not matter what others do. You know the rules and should follow them. Thats the best reason for you. I feel that you would not handle the consequences of an inncident/accident
Why worry about 417 feet when you were already out of bounds?Answering the questions,
1- Returning, I did press return to home to point the drone in the correct direction, and the drone does not pass 28mph and I canceled and keep manually.
2- When the drone ask to return to home because the battery I let them take control again but I notice little late, was going up passing the 400ft (from the take off low ground) to 417ft even when when the drone ground level was below 400ft but I canceled the RTH and keep manually descending to 300ft. Also I keep descending and the bumps was the drone avoiding the trees. That's great.
3- The recording was spited in 7 files, 6 of them with 3.5GB and one with 2.5GB.
He obviously did NOT know the rules, violating 2 at least. Distance and VO’s.A simple explanation for you
The person i was replying to does know the rule. It was not aimed at the OP. You must not have read the thread correctlyHe obviously did NOT know the rules, violating 2 at least. Distance and VO’s.
My bad!The person i was replying to does know the rule. It was not aimed at the OP. You must not have read the thread correctly
Also, not sure there is rule relatec to distance. Its VLOS and this is not tied to a specific distance, but to the operation environment and your ability to maintain vision of the craft
I dont even care about VLOS...Great post! Really disappointed by all the people (Mod Removed Language)about VLOS in here though, this is not the place for you armchair police everyone...
