Hi everyone! Just wondering if any of you have this experience or is it just my system? I am flying my
Mavic Air 2 with my
Smart Controller and each flight, I have to "Bind" the
Air 2 to the
Smart Controller. It's not just power on and it connects. Every time I power Off, and change batteries etc, I have to re-bind on the next flight. If any of you have and ideas as to why, or any info, please post up here. It's just a hassle to have to re-bind on every flight. I do not have this issue with the
Mavic 2 Pro and
Smart Controller. Only with the
Air 2. Thanks everyone!
Hi SaltyPilot, I too have the
smart controller and use it with my
mini2,
m2z, and the
ma2. Once you fire up the
SC and the main screen appears... if you select the connect on the left of the screen, it gives you the option to change aircraft. if you select your aircraft type from here, it will want you to bind your AC again.
Let's say, on my last flight i bound it to my to my
m2z, fly, then finish the flight and shut everything down. later i fly again with the same aircraft, all you have to do is turn on the
sc, turn on the aircraft. in this case the
sc will auto link with the
m2z which was previously linked and the go4 app will appear. connected! no re-binding. JUST DON'T HIT THE CONNECT OPTION WHEN YOU FIRE UP THE
SC" otherwise the
sc will think you are selecting a different ac and will want you to rebind.
another way to get flying quickly, if you haven't hit the connect button, is to turn on the
sc, tap the little icon on the lower right which takes you to the main screen. in the case of my
m2z, once at the main screen i select the go 4 app, let it start, turn on my
m2z and i'm connected. no rebinding.
The only time you need to select the connect button again is if like in my case, i decide to fly one of the other birds,
ma2 or my
mini2. Or maybe after a firmware upgrade. haven't had that happen yet.
also forgot, if you previously were using the stock controller when you setup your
ma2, your
sc has to also be bound to the aircraft and dji's database. in the dji fly app this is done under the profile settings in the fly app.. had to do this as a one time shot with all three of my birds that work with the
sc. when i switched back to the original controller had to go through the same processs.
hope this helps!
happy and safe flying
inno
