Hi,
I'm going to buy new Mavic Air 2 and I have a problem deciding between bundle with Smart Controller or standard Air 2 controller with dedicated phone to flying.
Smart controller seems to be better in almost all aspects with exception of automatic flying. Looks like the only app that can be installed and has support for Air 2 is Dronlink, but I've found information on their site that the performance may be poor due to SC old spec.
Another option would be to buy dedicated phone, most likely IPhone XR, but when I did the research I've found few potential issues.
1) Do you have any experience with Dronlink and SC? Any problem with performance or isntallation?
2) Does the Fly app for iOS has option to disable charging from controller? I know it was removed at some point, but has it been restored?
3) With charging disabled, do you stil running into situation when iphone overheats and the screen goes dimer?
4) The clamp on Air 2 controller hold the phone only from top and bottom. How tight is it? Will it hold the phone if for example I hold the controller turned 90 degree? Or will it slip away?
Thanks
Thanks
