With everything connected (tablet micro usb to the controller standard usb) my controller appears to be charging my android tablet - what's the solution ?
Er is geen probleem. Dat is normaal. Bij Android heb je automatische oplading. Bij IOS is dit bij mijn weten nog niet voorzien. DJI GO4 app zou normaal moeten werken!! Succes88
There is no problem. That is normal. With Android you have automatic charging. As far as IOS is concerned, this is not yet known to my knowledge. DJI GO4 app should work normally !! Succes88
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
