Of course I can fly less agressive but this is not solution. If I'm right event if I'm accelerating slowly it's still pitching. I will check it and post results.
You can also reduce braking in the settings to reduce the effect, and make sure to tilt the camera down a little so that it's already low enough and won't be forced down.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
