Mavic mini can't connect after crash
Chtybocal
Tasmania
Hi everyone,
Mavic mini crashed in water,
After drying, it turns on as usual but can't connect to the controller.
I format the sd card
Reinstall dji fly
Update drone on assistant 2
Pairing mode activate after 4 sec press
But not pairing
Any ideas?
Was there any visible damage to the drone?
The antennae are in the front landing legs, could it have broken one or both?
Could their wiring be damaged? There wiring has pop on/off connectors on the bottom board, could those connectors have been displaced?
Could some of the electronics have been damaged by the immersion?
Was the water salt or fresh.
So the weak link on the Mini when truly submerged is the ESC module , good chance that is compromised. If you send it into DJI they are most likely going to replace the Esc mod and the main Board.
Phantomrain.org
Gear to fly your Mini 2 in the Rain. land on the Water.
Reactions: Faster
Alienatrix
