Mavic mini does not connect with Remote controller
Status
Not open for further replies.
Carlos Martinezz
Mexico
Hello from Mexico !!
After 37 sucessful flights with my new MM, today I could not pair the MM with the RC.
I have found in the owners manual the following process:
* Press and hold the power button for more than four seconds, RC beeps continuously
* Press and hold the power button of the aircraft for more than four second, aircraft beeps once indicating is ready to link
I have tried this process some times with out sucess until now
I would like to know if some one from the forum has had similar condition and if there is any alternative option I could have to correct the problem
I really appreciate any support.
It is rare for RC/AC binding to be lost on its own l, but some have found that happen after firmware update. Be sure RC and AC are close to each other, like within a couple feet.
Some have found binding works after removing the SD card, and problem returns when SD card is put back in. Solution was to format the card on a PC, after which all was well even with the card installed.
Status
CraigAE
