Mavic Mini from Spark ?
techguy
Louisiana
I have a Mavic Mini set to arrive in a couple of days. I currently have a Spark.
Is there anything I need to know in moving from one to another that others have found?
I fly my Spark with an ipad mini and a "OTG" cable, should that transfer over ? I know the Mini actually uses a cable now, is it proprietary ?
Admittedly I got it since its under 250g and has 30 mins of flight. One less thing to worry about and twice the time to enjoy.
The mini is a much more delicate aircraft than the Spark so handle it with care. The props are especially vulnerable - make sure they don't get squashed, even slightly, when storing it. The MM comes with a set of USB cables of which one should work for the ipad. Your OTG cable will likely work too, if needed.
Bahamaboy242
