I hit a tree in Helix quickshot mode. I thought I cancelled it before it hit the tree. DJI says that I only stopped the video and didn't cancel the quickshot mode. Is it possible to stop/cancel the video only when in quickshot mode?
Better if you post the TXT log instead as that have more regarding the camera operation ...Flight log attached.
?Better if you post the TXT log instead as that have more regarding the camera operation ...
Geez ... could I have missed it, now the TXT is there in the OP's post ... could have sworn that it was only the DAT?
DJI Flight Log Viewer | Phantom Help
Upload and view flight logs from your DJI droneswww.phantomhelp.com
Rod
I was thinking that, but it didn't show an edit.
See post #2 - I just attached a test file - that doesn't list as an edit.
Well that's not very nice.
I just changed mine from trees to Trees.
Okie Doke.
Rod
A very good piece of knowledge to carry with you when droningThank you for the detailed information. I just need to stay away from trees
Did you find any info in the logs clarifying if the quickshot was manually stopped or not ... the question mark for me is that the Helix takes it's lap auto recording & then returns to start point per user manual description.The information from DJI was incorrect. The video was stopped automatically at the end of the quickshot mode, at 142 seconds. The aircraft hit the tree at 143.5 seconds as it was completing the maneuver.
In the log are info about recording start/stop & flyCState ... but shall that include the return trip or not. In this case it doesn't look like that ... so does that mean that the quickshot was manually aborted?
No difference at all for the outcome ... just curious to learn if something clearly showing us that in the logsI don't know whether it was completed or canceled, but its path intersected a tree. Does it make a difference?
