Hey, Guys, I have had my Mavic mini for a couple of weeks now and sometimes during flights (no Wind), the drone will just drop is altitude while im not doing anything, until it reaches the point to almost crashing. What is happening?
OK, thanks so much. For Free? and Even after 30 days?Not quite sure but I've watched a good amount of YouTube videos on this. Most of them had their Mini replaced by DJI because of a defective unit.
There have been several reports of similar incidents and quite a few Minis lost because of it.Hey, Guys, I have had my Mavic mini for a couple of weeks now and sometimes during flights (no Wind), the drone will just drop is altitude while im not doing anything, until it reaches the point to almost crashing. What is happening?
There's a real problem that DJI hasn't got on top of yet.
Post data from your flight to confirm if yours is another one to add to the list, or of it's something else.
That's why I just prefer my MPP. Don't need the mini for anything.Reading this is going to make me hold off on getting a Mavic Mini. I keep going back and forth but these stories put me back in check.
You should definitely do what u think is right, but even after these issues, I still love my mini. If you wanna see some videos with the mini go to Fisher Hirsch Photography on YouTube. This drone will be absolutely worth it if they fix their issue so maybe just hang tight for a bit.Reading this is going to make me hold off on getting a Mavic Mini. I keep going back and forth but these stories put me back in check.
Hey all I called DJI and they are giving me a free shipping label to send it in and get it repaired. I just hope this happens quickly.
What is happening?
ActuallyI live in the Midwest and it took 19 days to get MM back from trip to California repair center. If you get the report “no problem found” ...ask for another check. My MM is on its way back again with same original issue!
How do you post a flight log?Sounds like the Go-pro Karma - Perhaps the MM is the Karma Mk2 ?
On a more serious note, its dropping altitude for either of two reasons:
1) Its getting erroneous sensor input and trying to correct accordingly (think B737/MCAS issue plaguing Boeing)
2) Aircraft is sub-coming to the basic laws of physics and no longer able to sustain lift to keep itself airborne (possible crappy props, faulty motors, insufficient power etc)
If you post the flight logs from these affected flights the folks here might be able to determine what sort of issues you're experiencing and advise accordingly.
