I am new to this forum, this is my first posting, but have read lots of other pilots threads. Thank you for all the help that you give other pilots. From a novice point of view I have learnt a vast amount from other pilots on this forum.
To day I put the MM on the launch pad ( in my back yard ) went through all my checks , Calibrated the compass. Waited until I had 11 signal etc.and was ready for take off.
My intention was to fly through an obstacle course I had set up in the back yard.
I started the MM by pulling the sticks down towards the centre . The prop motors started. I then proceeded to lift off by pushing the left stick slowly up . The MM lifted off up and started flying backwards without me doing anything. I panicked as I thought the MM was going to crash into our house wall and grabbed the MM . The result, cut my finger quite deep on the one prop. Lesson learnt never try and catch the MM when flying backwards unless you know how. I guess this was a natural reaction from a novice. ( making excuses for my self)
What do you guys think I did wrong. ( apparat from being an idiot and trying to catch the MM) .
After fixing up my finger, with plaster and duct tape over it (as the bleeding would not stop and was messing up my controller) I tried to take off using the manual method many times after that . I noticed that the MM does move backwards quite a bit when taking off . But does not shoot backwards once in the air. It does not take off and go up without moving forwards, backwards or sideways in both directions.
I take off using this manual method with my MP2pro and it just lifts off the pad and goes up until I stop moving the LH stick up.It does not move backwards.
My Mini never used to do this. I used to push the stick up and it went up.
The Mavic mini once in the air hovers and is very stable , it does not move until you make it move.
I await your replies. You guys be Safe.
