It's a common problem. Most people ignore it and use the map to navigate home.Hi guys when I fly my mm on my phone the circle telling me my position seems all over the place to cut a long story short the small position arrow just rotates around the circle.
any help with this is appreciate.
Happened to me today as well. Was showing opposite of true position. Never happened before. Recalibrated and no change.Hi guys when I fly my mm on my phone the circle telling me my position seems all over the place to cut a long story short the small position arrow just rotates around the circle.
Recalibrate what?Recalibrated and no change.
Recalibrate what?
I had the same problem and recalibrate Mini's compass several times, but it appears that it was phone compass that was not calibrated, and I was not able to calibrate it, it somehow stuck at "low accuracy", several compass apps goes wild, so I just reset phone and only then was able to calibrate PHONE compass, and after that everything was fine. Sometimes goes wild again but then I recalibrate phone compass again and that fixes it.
The indicator often doesn't work. The controller gives off a magnetic field that can interfere with your phone/tablet compass. Try clipping your phone into the controller and waving the 2 together in a figure of 8 pattern to recalibrate the phone compass. It might help, might not.
Personally I ignore the indicator. If i need something to show where the drone is in relation to me I use the map as it is far more reliable.
However, it's not a problem for me since I have never really used/needed the pointer
