Hello everyone,
I need your help, my drone crashed the right arm was broken and gimbal holder as well
I changed the arm and fixed gimbal with activator and special glue for plastic... everything seemed ok, drone turned on without issues and also self check (gimbal and arm ) on the beggining....
the problem ist that I cant connect drone to controller, i have tried all kind of conecting, firmware updates, 4second hold, using different phone and it is all the time the same problem, plastic bottom of the drone around sensors is a little bit broken but black cover of main board and main board itself looks without problems, what can I try? I also try tu disconnect and connect antena wires and also use antena of broken arm but its not working
Maybe something like hard restart would help but I tried everything thorugh dji assitant 2 software
Maybe something is missing in drone?
Thank You
Thank You
