Mavic pro lens fog
David Moffat
Scotland
Hi love my mavic pro but last flight had an issue, inside my lens fogged up,
Can anyone advise me pls how to fix and prevent this happening again,
Regards David M
My len is fogging on the inside of the camera.
Any additional assistant would be greatly appreciated. I know the system is open, and I have kept my drone in my cold conservatory and then flew it on Christmas day where is was warm over here in the UK.
Really annoyed as I was flying on a perfect day and I couldn't record because of the fogged lense.
I'm going to try silcoset which should draw the moisture out, but has anyone else had better luck with a different method?
I use to aim my camera down and let the prop wash equalise the temperature, but it hasn't worked this time round.
Recently I’ve got fogging dead centre on my mavic pro, it’s on the inside and ‘only’ appears when it’s on eg it’s not there, switch on and connect so camera is running, appears after a minute or so, disconnect and switch off, disappears!
My conclusion is that there is sufficient moisture inside for this to happen.
I’m “super drying” out the drone with silica gel in a sealed container, 24hrs and will report my findings back.076210E8-CD88-4FA0-86BA-7C5EB577FA39.jpeg9257B5AB-BB93-4FBE-A098-1596094F90FA.jpeg
del60
