Mavic Pro Platinum - Compass error in sport mode
Eva.NT
Brazil
Hi guys. Help solve the problem. In sport mode I always get a compass error. if in the street it's windy then I get a compass error. I calibrate the compass according to the instructions. I'm doing everything right. What could be the problem? Help me = (((
Wearing Apple Watch? If I wear mine I get this issue
Reactions: Eva.NT
I've understood. At my drone, both compasses are magnetized because of transportation in the trunk of the car. I was told that they can be demagnetized by the Cfixer.
I'm having the same problem.
when in sport mode it shows mw compass error from time to time.
in normal mode everything works fine
any suggestion? (beside buying anything)
Not sure if still relevant to you, but look for "degaussing".
CFixer is simply a degaussing device.
Then at both the rear and front compass bring the degaussing coil or device near.
Now, while the alternating current is running through the degaussing coil you can start to slowly remove the coil from the compass until e.g. 1 m away.
I will try to detail more if necessary.
petravka
