anyone have any suggestion on where to purchase a mavic pro plantinum front leg? Will buy the entire arm if needed.
Left side
Again, not knowing where you are it's hard to recommend a place. I just used this dealer to replace my right front Mavic leg. Drones Plus Dallas | Same-Day Repair It was a very quick turnaround. Not inexpensive, however. Most places will likely want to replace the whole arm but this was the leg that broke off.
Yes it will unless it an authorized DJI repair centerFrom Massachusetts
I did purchase DJI care. doing the work myself or having someone else do it will void the warranty??
However, if you lost that leg as the result of a crash, then your warranty is already void. Any crash, I'm told by a dealer, voids the warranty.Yes it will unless it an authorized DJI repair center
This is true. Any crash does it.However, if you lost that leg as the result of a crash, then your warranty is already void. Any crash, I'm told by a dealer, voids the warranty.
I thought that Dji care covers damage from accidents?
I think he’s referring to the warranty mate
Apologies for bringing this up. Does breaking (slightly) a leg while in the case configure as a "crash"?However, if you lost that leg as the result of a crash, then your warranty is already void. Any crash, I'm told by a dealer, voids the warranty.
Probably not, especially if the flight logs all appear normal.Apologies for bringing this up. Does breaking (slightly) a leg while in the case configure as a "crash"?
