Can you put a Platinum ESC into the Mavic Pro? Will it just drop in, update firmware? Or how could you do it?
Cheers, Dave
Cheers, Dave
Phantom 4, Mavic air and mini have seperate ESC board.The ESC hasn't been it's own set of boards since Phantom 2.
Even if you could replace the ESC circuit, I don't believe the main board input would be compatible. Might as well just upgrade to the MPP AC.
Thank you for the clarification.Both ESC and main board are compatible. It will just show up as a mavic platinum in the go 4 app and assistant 2
Shout out to Jack one of our skilled techs for his quick response
See post #4. Seems it's a go Mate.Can you put a Platinum ESC into the Mavic Pro? Will it just drop in, update firmware? Or how could you do it?
Cheers, Dave
Hmm...not sure as I am not a tech and it’s too late to text JackBut you'd be replacing the main board and ESC together, wouldn't you? I assume OP was expecting to replace just the ESC cheaply.
A safer assumption would be that the OP had access to a platinum FC/ESC board. It is unlikely he might have something that doesn’t exist.But you'd be replacing the main board and ESC together, wouldn't you? I assume OP was expecting to replace just the ESC cheaply.
Why do you do this to yourself? The questions were is the pro/platinum ESC board a direct drop in for the pro -and- is it as simple as a swap and firmware flash?Not at all. Many think it might be easy to upgrade from one sub-model to another by just replacing a small component or firmware or both and ask if and how. I don't believe it's as trivial as the OP seems to think, and there's no indication the OP already has Platinum components on hand.
But there likely is no separate ESC board but rather the ESC circuit is part of the main board. THAT is the issue I am pointing out. If it's cost effective for him to replace the main board, by all means do it. I wouldn't think it would be cost effective but only the OP can answer that and he hasn't replied for some time even to clarify what he meant and has so we are both speculating.Why do you do this to yourself? The questions were is the pro/platinum ESC board a direct drop in for the pro -and- is it as simple as a swap and firmware flash?
The answer to both questions seems to be yes.
Basic tools and reasonable mechanical aptitude and it’s a close to trivial task.
I’d say it’s a three beer job at a nice relaxed pace.
Curious, but why did you downgrade your MPP to MP functionality?FYI...This is not exactly the same thing, but I replaced the main board in my MPP with one from an MP. It has been working for hundreds of flights. However, in my case I continue to use the Super Patcher and jkson5 mods, and I’m not sure if that makes any difference on the issue of compatibility. In other word, I am not using the latest FW.
Its hard to know what you are pointing out as your various responses make it difficult to follow.But there likely is no separate ESC board but rather the ESC circuit is part of the main board. THAT is the issue I am pointing out. If it's cost effective for him to replace the main board, by all means do it. I wouldn't think it would be cost effective but only the OP can answer that and he hasn't replied for some time even to clarify what he meant and has so we are both speculating.
I bricked my main board and needed a replacement. One from an MP was available. At the time, it was a shot in the dark. But the change has not downgraded or lessened the AC functionality. When it boots, the Go 4 app image still switches to the Platinum.Curious, but why did you downgrade your MPP to MP functionality?
"if you are mistaken"? Amazing......OP never indicated he was dead in the water, which is what I am interpreting you're saying by "back in the air". As a matter of fact his only post was post #1 so it seemed to me he was only looking to upgrade a working M1P to work as an M1PP by means of changing a board.
It wasn't stated for a fact the ESC was a separate board. DDS was going to get details from his tech but hasn't yet, or your argument distracted me from a confirmation response from him.
If the ESC is indeed separate from the main board providing input to the ESC circuit, and the input provided by the M1P is compatible with the M1PP, then sure, it's a possibility even economically. Seemed unusual to me though and wasn't the case with the Phantom 3 unlike the Phantom 2: it only had one board for flight.
Because of the methodology change of the ESC between M1P and M1PP, their expected input could also have been different. If I'm mistaken, I stand corrected .
The key difference between MPP and MP is how the motors are driven: pulse width vs sine wave power modulation.I put a MP core board in a MPP and everything behaved as if it was a MPP. The power board is the ESC and the flight controller and that dictates MPP or MP identity. I understand that the motors are slightly different in the MPP though?
The core board just handles the media manipulation, Wi-Fi, collision avoidance processing, RC messaging.. Etc..
