Mavic pro update
JohnnyD913
Arkansas United States
Using an iPad mini5 I connected as usual to WiFi and remote/ Mavic..
Started the update but kept knocking off the WiFi at 2%..
Tried and tried but same result..
Now my camera is pointed in a crazy direction and failed to update...
Tomorrow I will try to update with my iPhone XR..
Also I had my cellular data turned off so as to use WiFi only..
My question is:
Will it continue where it left off and will my camera fix itself?
Thank u
The safest way to update is to use DJI Assistant 2 on a PC, especially after having problems with the DJI Go4 app
If you have missed a few updates, you need to do them in sequence or you could run into problems.
Reactions: JohnnyD913
I'm not saying you are wrong but I've never had a problem skipping over updates with anything (drone, pc's etc...). Usually it's just a point A to B update. Nothing usually matters in between but I could be wrong.
I did the upgrade with the go app via iPhone 6 without any problem. Te batts of all devices were fully charged.
You can do that with DJI Assistant too as Turfagon suggested. Be warned,,you must avoidall conditions that can disturb the upgrade the firmware of the Copters system.
Distrubing coditions are:
*Batts charged less than 50%
*unstable Networks especially internet
*too many prcesses on the mobile or PC
*defective wires between the system and PC/mobile
*too fragmented SD cards in Mavics slot
maniac2000
