Mavic Pro V1 mobile device location iPhone 8
Vernon BC
Running latest firmware on Mavic pro as well as controller and goggles with iPhone 8 most recent IOS updates. Latest version of Djigo4 running. Permissions set to allow mobile device location access to djigo4 always. Unfortunately running into warning unable to set mobile device location. Started reading threads. Only solution found was a hover then unplug iPhone and replug in usb to set mobile device location. Could anyone be so kind as to direct to a thread with any other fix? I haven't quoted firmware numbers and software versions only because they are quaranteed the latest versions accross the board. Does this only on IOS which has gps capability built in. Huawei P20 pro Android tried and works without issue. I use both devices purely for flying with no Sim installed.
I have tried to do due diligence by reading and searching but only finding many dated reports of the same issue.
Best wishes to you all and thank you for keeping this forum alive and well.
James Hoogenboom
