mavic pro videos
cheolk
My new Mavic Pro videos are all fuzzy, streaky and horrible to look at.
I reset the camera settings in the Go app to default. Still like that. Is the camera faulty? However, when I, start the AC at home, the videos is ok, NOT flying.
Reactions: panam10
From the phone. SD card? Meaning you take out the SD card from the AC and insert into the computer?
Yes, something wrong with the phone. The videos from the SD card are beautiful.
Any solution beside using another phone?
You can use another phone but results would be the same.
The video on your phone is just a cache low res video.
Use the video from SD card.
Yes, you are right. Whatever phone used, it is not the same as from the SD card. No point buying an expensive phone. Maybe the cabling is no good or the image is a secondary one as the primary image is onto the SD card.
Thanks Buddy.
testtest
