After flying over the cliff, the Mavic will continue to fly at the same altitude until you manually increase or decrease it. Also, the height (altitude) displayed at the bottom of DJI GO won't change since that value is the altitude over top of the takeoff point. You won't hit the max altitude until the height displayed at the bottom of DJI GO reaches your max altitude setting.
I think he’s asking if the max altitude applies to a negative altitude as well as a positive altitude. Like if the max altitude is set at 300 feet will it be restricted to a -300 feet as well? I think so but I am not positive.
I do know that it can’t possibly know that it’s 300 feet above the the bottom of the cliff so it will either stop at -300 feet or go all the way down.
Anybody know?
Firstly - that's not what he is asking. He is asking if, when the aircraft finds itself at 500 ft AGL above the floor of the valley when its maximum altitude is set to 300 ft, will it immediately descend 200 ft to remain within 300 ft AGL. Since the altitude limit is relative to the takeoff location, not the ground under the aircraft as it flies, the answer to that is no, it won't descend. Additionally, unless it is within 30 ft or so of the ground and therefore within the range of it's downward VPS system, the aircraft has no way of knowing it's altitude AGL because it doesn't have a digital elevation model on board - it only knows barometric and GPS absolute and relative altitudes (relative to takeoff point).
As for the question that you are asking the answer is also no - the altitude limit is the maximum altitude above the takeoff point. It is not the minimum altitude below the takeoff point. There is no set minimum altitude.
You likely wouldn't want to do that since it would reset the home point to that new location. However, you could still manually fly back to the previous home point if the remote controller is still connected to the Mavic.if I landed at the base of this 500ft cliff, shutdown and restarted, I wouldn't be able to return to my original starting point, at the top of the 500ft cliff. Correct?
However, if I landed at the base of this 500ft cliff, shutdown and restarted, I wouldn't be able to return to my original starting point, at the top of the 500ft cliff. Correct?
I think you have to actually stop and start the motors for the home point and height to be reset. But, you’re right about needing to increase the max altitude in order to make it back to the top.Actually the barometer is reset on takeoff and landing
I also appreciate this Post, since I had the same question in regard to flying over a lake I live by which is maybe 65 feet below where the takeoff will be at my house and using Litchi Waypoints. My concern was on it's return home would it be at a lower altitude than set by the takeoff point. I did not want to assume it would not safely fly over trees, although the altitude set should have been good enough if the altitude would have been set to the lower elevation.
