So, you need an SD card in your M2 to get the fullest out of its shooting ability and quality, as the write speed over the air is not sustainable, that why cached video renders in 720p. Also I dont believe you can cache video to
SC unless your recording to the M2s storage, whether that be the SD card or the M2 8GB internal?
The
SC has internal memory, of course, but not much, so an SD card in the
SC can be used as its default storage location, which is selectable in the
SC menu, after the card has been installed in the
SC and it must be formatted.
It really just makes for more default storage space on your
SC.
Unfortunately, other than using Go share, as someone mentioned, there is no way to wirelessly transfer your highest quality, over 1080p, from M2 SD card to the
SC's storage, whether it be internal memory or SD card (via Go4 file viewer, you can transfer up to 1080p video though) so your left with the video caching function, in Go4 in order to get real-time video shot on your M2 and stored to your M2 SD card, to also save to your
SC default storage, however, that video will only be 720p.
I do alot of screen recording, so I chose to add a 128GB SD card to the
SC. After selecting it as SCs default storage, now everything saves to it, the DJI logs, the Screen Recording, etc. I believe if you used Go Share to wirelessly transfer your over 1080p video, it will also store to your selected
SC default storage, so it all comes down to how much and how long you will be keeping files on your
SC.
I keep alot on the
SC and do one lump transfer via PC about once a month or so, but if your transfering to your
SC then offboard to a HDD or a PC, in the same week or so, then No you really dont need an
SC SD card, but DJI did do something somewhat unique as far as android OS' go, by allowing an SD card to be read as default storage, so IF you make your SCs SD card your default, dont forget that in Go4, your options will be flip-flopped, I think, so if you choose to save cached video to SD card, then itll save to internal and vice-versa (test this out yourself as they mayve changed it or I may be wrong?)
One last addition as I'm not sure what you meant when you stated that you formatted both cards, then installed them. Im not sure if you formatted them outside of the M2 and/or
SC (like in a PC or another digital camera?) so Id like to recommend that you format both cards in the device for which they will be used. ie; Format the M2 SD card, in the M2 and format via Go4. Same with
SC if you keep one in there. The file systems are slightly different that those in PC's or other devices, plus its just good practice anyway. Sorry if thats what you already did.
You may get strange occurances or corruption if your attempting to use SD cards in multiple devices. I learned this the hard way long ago and now have 3 older SD cards that I cant even format, partition, or even write zeros to, all because of 3 bad sectors.
Good luck & Hope this helped some...
