Mini 2 protective case
waynger
santa cruz, ca
3D printed case, hold drone and case vertical and set it in. No need for gimbal protecter but you can use it if desired. This is designed to protect the mini 2 while it is in a bag or backpack.
FWIW I have been using this and it works perfect. It is designed to be used without the gimbal guard and you simply drop the Mini2 in it
DJI Mini 2 Drone Case
It works like a drone holster and is super-fast, certainly worth a look
maniac2000
