I have mentioned on other threads that I am getting more comfortable with the MM, so I have been pushing the limits. I am more comfortable with the sticks and how the drone acts in C mode. So I have been flying in P mode with a bit more speed. As a result, I have done some weed eating in the fields. I haven't had any crashes, but I have flown into some weeds and landed in the grass twice. Each time I noticed nicks in the blades so I replaced them.
On Friday I was doing some flying between trees and branches and flying low in the field. I also did some fast circular flying around a lake to get used to adjusting the sticks to stay on course. It was a good day flying. On the way home I found what I thought to be a great video shot. It was railroad tracks with trees on both sides. So yesterday I drove out there and proceeded to fly the tracks. It was a horrible flight. No matter what I did, I couldn't keep the drone flying straight. I was about 4' above the tracks and it would drift to the right. So I bumped the right stick to bring it back and it would continue off to the left I bumped the right stick again and it would drift off to the right, over and over. Also, on a few occasions, the drone started dropping altitude as it flew forward. I would bring it back up and it would stay up for a while and then start dropping. It did this in both P mode and C mode and with 11 satellites showing on the controller. I finally gave up.
Today I replaced all of the props. I did a compass, IMU, and RC calibration. I then flew it out in front of the house, and in C mode it tracked perfectly. In P mode it still drifted a bit, but I was able to easily correct it and that was with the drone flying about 2-3' off the ground. I did this with 11 satellite connections.
What I found was when I was replacing the props, the rear props were very loose, all 4. I know when I change the props, I tighten them until the screw won't go any further and then check the prop for clearance (to make sure the screws went in straight). I don't know if I just missed it last time or they started backing out, but I'm guessing that was what the problem was yesterday. When I flew today, the props were all tight.
So this new experience has brought about some questions. Is P mode less accurate or stable than C mode? Because today the drone drifted a little in P mode but none in C mode. Is there an altitude that if I fly below it the drone is less accurate? Yesterday I was flying around 3' above the tracks. Today I was flying 2 - 3' above the street. Is the drift normal in P mode, or maybe is it normal when flying so close to the ground, or maybe it is normal but not noticeable at 50'?
I have searched the manual and these threads. I don't know if the calibrations did anything to help, but I am sure that the loose props were causing yesterday's unusual flying patters, it follows the behaviors found by others with warped props. Maybe both needed correcting. But I am trying to find out what behaviors are normal between modes and also at different altitudes.
Thanks for any info you can provide.
