This is a real engine, it is small and electric.
The electrical engines are controlled by other means than the actual load, although under load that mechanism and depending on the application may also control so that the engine keep the same speed.
If there are no load on the engine the speed will not be greater than the speed the input "tells it to have".
It would merely spin easier and draw less amp from the battery.
