Moverio BT-300 disconnected.
airakti
Hi, I just obtained the Moverio BT-300 classes and I've Mavic pro2. My problem is that classes and mavic do not connect each others. I've reinstalled DJI go 4 application and Moverio has the latest Android version. DJI go4 app shows status: Disconnected. Any ideas what I could try next?
Hi There, I have just got the glasses too and am havi g the same issue? Did you manged to solve it? Thanks
Hi, yes I did. Fault is that I had mini usb connected to the controller side. It reconized although other side was loose. Remove mini usb too and I hope this help you too :-)
Reactions: fozza
Hi, yes I did. Fault is that I had mini usb connected to the controller side. It reconized although other side was loose. Remove mini usb too and I hope this help you too :)
Legend! That too was my issue! (faceplam)
Been having fun this afternoon flying Mavic Pro platinum with the glasses. Works great.
What else are you using yours for?
Thanks agian for the help
Reactions: airakti
miajohnson
