- Joined
- Nov 22, 2016
- Messages
- 37
- Reactions
- 12
- Age
- 46
Anyone else getting multiple crashes while using dji go on iPhone? Had the drone up for about 15 minutes and it crashed about 4 times. Running latest firmware of dji and ios 10.3.3.
You must have one tough Mavic to still be flying after that.![]()
Last sunday, this happened to me for the first time, the app was unable to work more than 20 seconds. Pretty scary with the mavic in the air. Even by itself, with the drone shut off, the app crashed every 20 seconds. I deleted it and reinstalled it and now it works fine again. I hope it will work for you!
Update your IPhone to the new 11.2 versionAnyone else getting multiple crashes while using dji go on iPhone? Had the drone up for about 15 minutes and it crashed about 4 times. Running latest firmware of dji and ios 10.3.3.
Voila problem solved!
You need to update to ios 11.2
No, loss of the app functionality will not cause the connection between the craft and controller to lose connection. The app has nothing to do with that.I am a new user, and reading these posts make me worried. If for any reason the app crashes, does it mean it can lost signal with the drone and crash it wherever it will be? an if it crashes when you're flying what has to be done? I am using an ipad mini 4
Hmm, that's not my experience. I have had the controller stop controlling the aircraft after an app problem. Most of the time that hasn't been the case, but it has happened to me. Powering off the controller and restarting it restored the connection.No, loss of the app functionality will not cause the connection between the craft and controller to lose connection. The app has nothing to do with that.
