hi, i have already use all the latest firmwares 1.04.300 - 1.04.200 - 1.04.100 i ve already do calibration:imu,sensor,camera,remote control. i have try to set EXP-Sens-Gain .. but i m fiiling like flighing a boat..can anyone helps me to fix it?
If this is the case, then try a few things.As opposed to being perfectly still?
So you mean the drone still has movement with no input apart from the yaw input?
You might have a bad compass calibration. It looks like it's flying in Atti instead of GPS mode.I mean that my drone it has glides on the air when i turn it for example 180 degress..
You'll need to explain what you mean by flying like a boat
I would assume in that case the OP would have said it flew like a plane.Did you inadvertently select "Fixed Wing" flying mode from the controller?
