How do you "finally" find a ND filter set for something that hasn't been available for 1 day?
You might want to post these in the DJI FPV Forum .
Because normally filters, bags etc.... are out 2-3 weeks ahead of timeHow do you "finally" find a ND filter set for something that hasn't been available for 1 day?
Your normally and mine are vastly different. There could be no such market for DJI nor has there been from my observation. DJI is hush hush on their releases, so if someone was to market third party add ons for a device yet to be released by 2-3 weeks, they are in great violation of a NDS that was granted by DJI, and as such would be removed from any further consideration. Simply never happens from any of the 5+ years of my flying DJI products.Because normally filters, bags etc.... are out 2-3 weeks ahead of time
Hush, Hush LOL. Their has been photos and video of the new FPV for at least two months nowYour normally and mine are vastly different. There could be no such market for DJI nor has there been from my observation. DJI is hush hush on their releases, so if someone was to market third party add ons for a device yet to be released by 2-3 weeks, they are in great violation of a NDS that was granted by DJI, and as such would be removed from any further consideration. Simply never happens from any of the 5+ years of my flying DJI products.
Not nessary yet till all these threads are moved to that forum. ?You might want to post these in the DJI FPV Forum .
Phantomrain.org
Gear to fly your FPV in Extreme Weather Coming soon.
Having one axis or two doesn't really matter. Reducing shutter speed is a common cinematography technique, and can be explained by the 180 degree shutter rule. While the this rule is antiquated and explains the relationship of frame rate relative to shutter angle on old film cameras with rotary shutters, we can apply the concept to the digital format, as a simple way to describe the appearance of motion blur in video. By reducing shutter speed relative to your frame rate, you can control the appearance of motion blur. Traditionally, the most common setting in cinema has been a shutter angle around 180 degrees. For digital applications, this translates to a shutter speed at double your frame rate.Genuine question. Why would you want ND filters for an FPV drone? This isn’t like a Mavic. It only has a one axis gimbal, and two frame rates (30 and 60), so it’s not really intended for filming.
Yeah, I know why you’d use them on a cinematic drone, I just don’t get why you’d want them on an fpv drone.Having one axis or two doesn't really matter. Reducing shutter speed is a common cinematography technique, and can be explained by the 180 degree shutter rule. While the this rule is antiquated and explains the relationship of frame rate relative to shutter angle on old film cameras with rotary shutters, we can apply the concept to the digital format, as a simple way to describe the appearance of motion blur in video. By reducing shutter speed relative to your frame rate, you can control the appearance of motion blur. Traditionally, the most common setting in cinema has been a shutter angle around 180 degrees. For digital applications, this translates to a shutter speed at double your frame rate.
Why can’t an FPV drone be cinematic?Yeah, I know why you’d use them on a cinematic drone, I just don’t get why you’d want them on an fpv drone.
One axis gimbal to start with. Then there are only two frame rates. No flat profiles. Much wider field of view (150 degrees), all of which make it much harder to blend with footage from other cameras.Why can’t an FPV drone be cinematic?
