Maximum polarizing effect is at 90 degrees to the Sun. Point the drone there before launching and rotate the filter, noting the darkening on your screen image display. Set what appeals. Best used to reduce reflections on water, highlight cumulus clouds on a bright clear sunny day and to add some mild colour saturation to vegetation and terrain. Just a guide here but test it for your own liking. Cheers.So I've never been one to believe in the power of a ND PL Filter, however I've decided to give them a go for a upcoming trip.
But where does the line line up for example of I'm fling over cliffs and water?
Thanks View attachment 110062
I assume the line on the circular part is where the pilarosing bit is?The "90 degrees" rule is for the sky. I generally aim at the source of "hottest" reflections off the water, dial to maximum interference, and call it "good."
Couldn't a standard ND filter allow for cloud photography?Maximum polarizing effect is at 90 degrees to the Sun. Point the drone there before launching and rotate the filter, noting the darkening on your screen image display. Set what appeals. Best used to reduce reflections on water, highlight cumulus clouds on a bright clear sunny day and to add some mild colour saturation to vegetation and terrain. Just a guide here but test it for your own liking. Cheers.
The reason is your cloud pics would be no different without the ND. Unless it is exceptionally poor quality it will only alter the exposure.Wy
That's what I use, with AEB bracketing, and am very happy with the results.
Is there a reason to use PL instead?
So I've had this debate with others on the forums and convinced them otherwise.The t
Are you using a graduated ND filter? Yes obviously that can prove very effective in balancing Sky to foreground in some instances (exposure). It has nothing to do with the discussion here or the OP query.So I've had this debate with others on the forums and convinced them otherwise.
I use my ND taking cloud pictures for a "graduated filter" of sorts.
It allows me the ability to have soft clouds, but sharp foreground.
Merge all AEB photos or just pick a single one?
Hey Guys, Lately I've been practicing my photography more (I do more video that photo tbh). Shooting RAW (with an ND-4 on from previous video work) and trying out different shutter speeds to get more practice and try to improve. What I would have typically done is shot RAW using AEB-5 and...mavicpilots.com
Convinced is a poor choice of words.Are you using a graduated ND filter? Yes obviously that can prove very effective in balancing Sky to foreground in some instances (exposure). It has nothing to do with the discussion here or the OP query.
What have you convinced people of?
The OP query was regarding filters. Yes, PL but filters nonetheless. ? (EDIT: actually the term "ND" is in the title soooooo...)It has nothing to do with the discussion here or the OP query.
My friendThe OP query was regarding filters. Yes, PL but filters nonetheless. ? (EDIT: actually the term "ND" is in the title soooooo...)
And the "discussion here" was a conversation I tired starting with you, looking for advice... My bad.
I take your passive agressiveness, and raise you, with facts. ??
I was going to quote this on the Zoom post where you referred to WiththeBirds, I didn't mean to offend.My friend
@WithTheBirds is the most knowledgeable person about cameras I know. You’ll learn a lot from him if you listen.
PL filters or polarized filters are for reducing glare and some reflections. They have to be rotated to find the best orientation of the filter and that’s what the OPs question is about. Some ND filters are also polarized but the OPs question is in regards to the PL portion of his filter.
Differing opinion? I answered what seemed to be your question. It appears my question to you remains unanswered though- what possibilities with ND have you "opened peoples eyes? to?I was going to quote this on the Zoom post where you referred to WiththeBirds, I didn't mean to offend.
Just asked a question, and seemed like when I had a differing opinion it wasn't valued simply because face value states ND filters are crazy-talk when it comes to stills, which you and I have already discussed.
I answered your question by quoting another thread on post #9, and sent screenshots in post #11.Differing opinion? I answered what seemed to be your question. It appears my question to you remains unanswered though- what possibilities with ND have you "opened peoples eyes" to?
That's barely an answer. Especially when my opinion is different.The reason is your cloud pics would be no different without the ND. Unless it is exceptionally poor quality it will only alter the exposure.
I explained this in the thread referenced above (post #9), and in my screenshots... But in a nutshell...How does your application of an ND filter give you soft clouds and sharp foreground? Time lapse? Stacked images in post? Both effects could be produced as easily with no ND.
I must confess I didn’t follow your posted link to the other thread.I answered your question by quoting another thread on post #9, and sent screenshots in post #11.
I can lengthen the shutter speed when shooting the sky, longer than I could without an ND filter.
I shoot 3 or 5 AEB stacked photos with no deghosting.
This provides a bit of motion blur, but because the foreground (the cityscape below) is stationary, it is sharp...
Time lapse was also covered in the other thread... That's a video, and entirely different.
How could you shoot at ISO 100, shutter speed 1/125 and get motion blur?
Please inform me.
He’s saying that he’s using the ND filter to get a longer shutter so that he can get some slight motion blur in the clouds therefore making them slightly softer.Differing opinion? I answered what seemed to be your question. It appears my question to you remains unanswered though- what possibilities with ND have you "opened peoples eyes? to?
I am genuinely interested in understanding what "facts" you are presenting here.
My understanding also- a good use for an ND. You can’t get a polarising effect with an ND though so not much use to the OP.He’s saying that he’s using the ND filter to get a longer shutter so that he can get some slight motion blur in the clouds therefore making them slightly softer.
That’s how I understood it at least.
Agreed.My understanding also- a good use for an ND. You can’t get a polarising effect with an ND though so not much use to the OP.
