Can you explain more. Thankshow can i stop my remote control charge
thanks but do you thank the dji wheel fix it??if it is an android phone there is not much you can do about it,to help matters to a certain extent make sure you have as few apps as possible running in the background and make sure the phone is fully charged before you connect to the controller also turn off cache to device in the app
They could simply not have connected the wire sending power through the USB port of the controllerOn Android (DJI kicks you out blame the USB shardware design structure) .. NO .. until some hardware architecture engineer .. has a good solution ...
what i meant by saying have the device fully charged, was not that it stopped the controller from charging the device,but to give you the best duration if you were flying multiple batteries
That goes against USB specs and could cause some Android devices to refuse to connect. Original USB specs state that the host (device acting like a PC, which is what the RC does in this configuration) is supposed to be capable of providing a connected device with 500mA. I suspect too that Android API doesn't natively provide a means to disable charging while the iOS does. Some brand phones might have "hacked" the OS and added that function.They could simply not have connected the wire sending power through the USB port of the controller
