- Joined
- Nov 1, 2017
- Messages
- 31
- Reactions
- 40
- Age
- 60
The top cover is very simple to replace you don’t disconnect any wires just remove the front sensor cover and the screws on the top cover there are 6 screws and the top pries off the only thing is when you buy a top cover there is no serial number and the serial number is in the battery compartment you can go to you tube and get a demonstration on how to replace it good luck and yes make sure it not the battery that’s swollen which is causing your problemsPlease see the pictures posted. I need to know if this part can be sourced and replaced by me. The drone flies with no issues but the battery does not "click" securely on one side.
PatrickThe top cover is very simple to replace you don’t disconnect any wires just remove the front sensor cover and the screws on the top cover there are 6 screws and the top pries off the only thing is when you buy a top cover there is no serial number and the serial number is in the battery compartment you can go to you tube and get a demonstration on how to replace it good luck and yes make sure it not the battery that’s swollen which is causing your problems
I ordered my through eBay just go on eBay and search mavic 2 parts I just looked and they have one for $20.89Patrick
thank you very much , Do you have a link of where to best order the part I need other than the battery?
Thank you
Armando
Thank you again.. Just ordered itPatrick
Thank you
Armando
M2P" data-source="post: 957634" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">You should consider disposing the battery based on the risks of battery thermal expansion. I work for the fire department and I´ve seen first hand, lithium batteries suddenly starting to burn. It´s a fire a normal fire extinguisher can not handle.
There are 6 screws you have remove to take the top cover on the mavic 2
