Need some basic pointers, this is my latest effoet and not very pleased with the results.
Thanks
I used Imovie to edit and it looked good.
Never made any changes during edit.
Uploaded as SD 480p (640x360)
Thanks for the links and tips...Maybe you can try uploading the full resolution video to youtube
Upload 4K Video to YouTube? Here You Can Find the Steps and Other Info Related
In this guide, we have collected every single details about uploading 4K to YouTube, like why we need to do that, what we need to care about when doing this job, how to do it, etc. Check them all now.www.videoproc.com
This might help changing the color and saturation in iMovie
Change the look of your iMovie project
Change the way your movie looks with effects like video filters, color adjustment tools, and the Ken Burns effect.support.apple.com
Thanks for the tips• During the orbit add some text to include information about the Diamond Tree i.e. its location, history, and what it is used for. That information is in the beginning but the video needs to be paused to read it.
• Replace the trip back down the tree with a wide pull back showing its placement in the environment.
Thank you for your pointers, it seems I have a lot to learn not only about droning but also general photography. It will keep my old brain busy which is goodI applaud your effort and desire to make your flights and videos better. Since you asked for "pointers"...
1) Try for more variety of perspective. While I recognize the brevity of the clip, the shots in this clip were limited to up/down and around. How about over the top looking down? Perhaps dronie or a rocket (both pre-programmed into the drone for automatic piloting). On a circle shot you don't have to use the full 360° trip.
2) I understand you were using the sign to provide setting information. How about some B-roll approaching the area, creating your own title? 2a) Try not to use static images in a video. Unless for come creative aspect the video should almost always be in motion.
3) Try to incorporate some views that have more dynamic composition. [Google "Golden rule of thirds"].
4) Make sure your transitions match the "style key" of the type of video you're making. I would have preferred dissolves or jump-cuts to a wipe transition.
5) Look to optimize the color/contrast/saturation/white balance. Can iMovie do this?
6) When previewing/reviewing, ask yourself how each clip, how each element within the clip makes you "feel", then edit accordingly. Perhaps this is the best piece of advice I could give.
Thanks for sharing.
To be honest, most of what comes off my drone is garbage. Drone going up, down, positioning, jerky flying etc. But the bit that isn't any of those things can usually be made into something good. I go through all of the footage, chop out the stuff I won't use, look for duplicates or similar and use only the best. People's attention span is short so you really need maximise your best bits
Hi Thommo,Need some basic pointers, this is my latest effoet and not very pleased with the results.
Hi Paul, the music is much better than I had, another thing I have to come to grips withHi Thommo,
Most of the comments are about editing and shooting techniques, there is nothing to add. I played around a little bit with the saturation and added a better fitting music, I hope you don´t mind
cheers Paul
All good suggestions Thank you.Keep in mind, I know zero about videography and I’m still learning to fly smoothly. I say experiment. Try these angles, you can always delete what doesn’t turn out.
1. Get directly above the tower, point the camera straight down and then fly the drone straight up into the air.
2. Start off level with the tower and close. Pull back and rise up to reveal the magnitude of the tower and trees
3. Hover the drone low (20ish feet) and about the same distance back from a point where you can walk into the woods. You walk into the frame and then off into the woods.
4. Is there a clear path to the tower in the woods you can fly without crashing that is 4 or 5 feet off the ground? If so, go slow and speed it up in editing.
5. Start level with the tower and it out of frame. Fly parallel to the tower to bring it in and out of frame.
Will any of these work? I’m not certain. Play around with it until you find something you like. I do think you are off to a nice start. Good luck.
