I searched the forum, but didn't find anyone having the same issue Im having. If someone else can find it please point me the right direction..
The longer I fly the more negative my altitude reads, from the same point I took of from. I have see as much as -16'. RTH works fine. I have also noticed that when hovering it seems to not be very stable at times. ascending and descending slowly when about 5' from the ground. I have calibrated everything, IMU, sensors. I have made sure the firmware is up to date. I contacted DJI support via facebook and they should I should send it in for a repair. this drone is less than 3 weeks old with only 11 hours of flight time. i hate to think it needs to be repaired, seeing as it has never been crashed dropped and kept in a protected hard case. Is there anything else I should try before sending it off? Its really disappointing this is my 1st drone.. Thanks for any advise
