New firmware v01.04.0000?
siagung
New firmware with adjusted color in normal mode in vivid and support for the little brother, the platinum and its low noise propellers. Also it added quickshot feature.
Wanna try this, hope they're really fix the color issue
Reactions: DOC_XDA
They did!
I cannot access log data . DAT files. Before upgrade when Mavic was connected to computer via USB after opening DJI Assistant, one could access a drive which was a folder in Mavic memory to access log files. Has anybody have the same problem?
I had my mavic up today and after reviewing the footage I think the color is much better with v01 0000
Hi,
did you try to select "Data Upload" instead of "Flight Data" in Assistant 2 ver. 1.1.6?
Don't you think with this firmware the image is a little bit over-exposed?
thank you
Nope, for me its contrast is so...awful. The exposure is acceptable now
Philip Chura
