I recently got an
Air 2S and am excited to use it.
mavicpilots.com
We also have Regional Sub-Forums for New York…
Welcome, New York Mavic Drone Users! Join the other Mavic pilots in your area to discuss local laws, restrictions, great places to fly, local drone shops, etc. Start a thread to introduce yourself and let us know where in New York you reside!
mavicpilots.com
Also, I'll let you Google "Doneing on Long Island" for locations and Groups active in your area…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2s, including the User Manual.
At DJI Download Center, Learn aboutMavic
Air 2
www.dji.com
Happy Droning…
