I don't know how to reinstall DJI Go4 on a smartcontroller, that on a mobile device it wouldn't be a problem, but on this one I don't Know , DJI Go4 on smartcontroller is a system applicationAnd just to add - at least one Android user has reported that he had to manually delete the DJI folder on the device after uninstalling, and then reinstall the app, in order for it to create log files.
I've already done this in a way that 1-st switch the default to internal, sync logs, switch back to SD card, and sync again.The flight records are now saved to Internal memory even if you have 'save to SD card' setting:
Internal shared storage\DJI\dji.go.v4\FlightRecord
If you want to have them sync to your flight records/DJI,
in the SC file manager, browse to that location/file, long press it, and copy (or move) to:
SD card\DJI\dji.go.v4\FlightRecord
Now it will show up on the home page flight records and can be synced with DJI
OR - someone else said you could switch the default to internal, sync logs, switch back to SD card, and sync again.
Haven't tried that yet...
