New mavic2pro owner/Flyer/crasher
charliesRig
Question:
cant seem to record on any of My SD cards I have selected From camera Menu External storage
still no write
is it as Simple as Formating the card Card's first .?
....cR
Is there a message showing up, that your SD-Card is to slow? If that is the case, that might be the cause.
Since you are not able to recird right now, you could just format the card in the drone and see what happens. If the problem is solved, then be happy, if not, we look for other causes.
Reactions: charliesRig
Here's the setting in DJI GO where you can choose the storage location:
78374
Thank for the input
Everything on the bird seem to work well
I do get the message that The card is too slow
I bought a new SD (200gb)
Swapped it out for (64gb)
Now I’m going to try my (128gb) out of my MP1
Should I have to select storage after every flight because I pull the card out to pull the data off .?
......cR
Your are right I didn't Need to select Internal/External storage
My issue Is Im still learning and still tweeking my Adjustments/Setting.
on MP1 just push the shutter button and it click right away
on the M2P I have to hold down a long second before it snaps a pic or
ingages Video.....(Thats on me)
Ok I took my 64gb card form MP1 and it works but say SDcard slow .?
It is a Luxar 633 64gb...xc1 (black/Blue)
.have any recomendation on a SD card.?
Just have to say The Mavic2Pro as an amazing flying camera (yes Im gushing now)
it is just so steady and smooth.!
If you have the means I highly recomend it
I've aired It out 4 times No crash
......cR
Reactions: Thomas B
If it's only the prop(s), you had luck.
Yesterday, I was flying at a small beach here in Sweden as suddenly a butterfly decided to fight the drone. A short "plopp" and the fight was over. No damage to the drone...
Reactions: Lbesing
I've been using only sdcards with the Class 10 / U3 rating, not the slower U1 rated cards. I haven't tried anything larger than 128gb yet, since I'll run out of batteries before filling up a 128gb sdcards. Lol
I've got 5 batteries for my Mavic 2 Pro and 4 batteries for my Mavic Pro. I'm only limited by the battery life of the RC controller, which is usually shorter than all my batteries so far.
Yes, if you want the aircraft not to report a "slow card" you have to use an UHS-I U3 one (or better obviously).
PetefromNZ
