Not that I'm super-experienced but I have been flying for 2 years with a
DJI Mini 2 and I have just upgraded to the
Mini 3 Pro.
mavicpilots.com
Since you live in Belgium, there are specific laws and rules for you to follow, please check to ensure these are current.
dronerules.eu
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Mini 3 Pro
www.dji.com
Fly On and Fly Safe…
