New member from Poland
Hello to every pilots, i'm fairly new with flying. I ended up here looking through various forums and found here a lot of interesting tips.
Ive got air 2 from few weeks and yesterday just got amazing mavic 3 classic, Hope to get a lot of great photos and movies.
Hello, I am also from Poland and I have just bought Mavic 3 Classic, Due to the bad weather I haven't flawn yet, but studied it carefully standing on the table. The difference is that I am an experienced dron pilot, operating Phantom 4 PRO for many years. So if you need any general help...
Good Luck
Krzysztof z Krakowa
Poland?! Wow! I really DO want to see some pics and/or vids from Poland!
I can't wait.
O yea, hello from Savannah, GA in the USA
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Since you live in Poland, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2 and the Mavic 3, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome and hello from Minnesota, USA.
jimcsnr
