New member from Shinfield, Uk
AndreaBB
UK
Hi guys,
I’m Andrea and I live in the south east of England. I’ve got some mini drones I flew for some years indoor and I have now bought a MM to let this lockdown be less boring.
As soon as I received the parcel from Amazon, I’ve got my Operator and Fly numbers, an insurance and then started practicing indoor, on the backyard and then in an open meadow.
I’ve already pre-booked the A2 CofC to (hopefully) be allowed to fly in Europe in the next few months.
ciao!
Welcome to the forum! :)
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome to the forum. I also fly a MM and have loads of fun with it. You will find all sorts of suggestions and recommendations here in the forums. Wish you well. We look forward to seeing your view of the world.
Since you live in the UK, there are specific laws and rules for you to follow and it looks like yu have it well in hand.
Even though you have flown your mini drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
Not the first time that I responded to a posting that was not exactly current and I am sure it will not be the last… Perhaps, these postings will awaken AndreaBB that we are still here and return…
Thanks for the heads up and I will try to be a bit more observant.
gfusato
