Grams verses visibility.
Your choice.
I'm not so sure that's a practical way of looking at it with the modest weight differences of the top contenders. I suppose if saving 1 or 2 or even 5 grams is important, then the Arc II is the obvious choice, especially because it is one of the thinnest strobes available and can be mounted on the bottom of most DJI drones.
The Arc V strobe weighs only 13 grams and puts out 1000 lumen. Dimensions are 25mm x 38mm x 14.4mm D (with velcro attached) [ 1" x 1.5" x 0.6 D w/velcro]. Not that it matters a ton, the velcro itself weights .7 grams (get the pun?). I'm not aware of any of the Arc V's competitors that throw 1000 lumens (pls correct me if I'm mistaken).
The Arc V's main competitor,
Lume Cube (or should it be vice versa?) is rated at 500 lumens, and at this moment on sale for $32.
Lume Cube's published weight is 10 grams w/o velcro and is about the same length as the Arc V, looks like it might be a little tougher build but looks "thicker" though no depth measurements are readily available. For some depth might be important if mounting on the bottom as we have to consider bottom clearance.
@msinger said: "Yeah, TOPSUN lights are highly underrated. They appear to be a little brighter than ARC lights (to my eye)."
Topsun has done a terrible job of marketing. I doubt that they are brighter than the Arc V at 1000 lumens. The difference between 500 and 1000 lumens is noticeable, but to the eye only slightly so. Back in June I had ordered a Topsun but cancelled the order because I couldn't find the specification and thought it might be larger and heavier than it actually is. they only stated visible distance, not rated lumens as the other companies had. They had advertised the PACKAGE weight, but not the strobe's weight and until today could not find the dimensions of it. I've now found those, but even now they don't state rated lumens, nor do the dimensions they provide (see photo below) include the height of the dome. As I wanted to mount the strobe on the bottom of my
Mini 1.
So my first strobe was a Firehouse Arc II strobe, 500 lumens-
only *8* grams with velcro attached 23mm x 30mm x 11mm D w/velcro [ 0.9" x 1.17" x 0.4" D w/velcro ]. On this purchase I opted for a separate "headlight" mount, but have not used the mount much, but is handy as the Arc II (and Arc V) have a continous output mode.
Note: Strobes were personally weighed on a jewelry scale that displays in grams plus two decimals.
