- Joined
- Aug 3, 2019
- Messages
- 4
- Reactions
- 0
- Age
- 123
New Pilot here... just paid $5 to register as small UAS Certificate of Registration w/the FAA. Is there anything else that I must do to legally fly
Check the sectionals to be sure your flight is legal at locations/airspace chosen.... obtain LAANC clearance as indicated.New Pilot here... just paid $5 to register as small UAS Certificate of Registration w/the FAA. Is there anything else that I must do to legally fly
If you're flying as a hobbyist, you need to follow these rules:just paid $5 to register as small UAS Certificate of Registration w/the FAA. Is there anything else that I must do to legally fly
This won't hurt anything, but there is definitely no benefit to doing it before every flight.Calibrate your compass before every flight
Have actually you had this problem with your drone?It actually COULD hurt something if a perfectly good calibration was fouled up in a less-than-optimal environment for no good reason.
The very SMART equipment has told me anytime it believes compass calibration is necessary. First use. And then each time I've traveled more than x number of miles it asks for calibration.This won't hurt anything, but there is definitely no benefit to doing it before every flight.
The compass calibration will fail if you attempt to calibrate the compass in a less-than-optimal environment. Give it a try and you'll seeIt actually COULD hurt something if a perfectly good calibration was fouled up in a less-than-optimal environment for no good reason.
Suggestion:
READ YOUR USER MANUAL THOROUGHLY!
Calibrate your compass before every flight.
First flight, use the auto take off function to initiate a take off and hover around 3-4 feet.
Then use the auto land feature.
Simple up and down.
You will smile, safely get up and down.
Next, do the same routine, only while you are airborne , rotate 360 degrees and set down-using the auto land function again. (Not return to home)
Smile and quit for the night.
Tomorrow, go find an empty softball park and do the routine again, and gently exercise the control sticks and get familiar with the RTH feature.
Be sure you are in the beginner program and NOT IN THE SPORT MODE.
Have fun, be safe, and keep us posted.
Thank you for your simple, thoughtful, non-technical reply. Being BRAND NEW to this adventure, it helps to hear your kind words.Suggestion:
Simple up and down.
